All the parts (with the exception of wiring) are here and getting ready for the installation. Lectrotabs 12x12 and ALC-1 (automatic) control plus Diablo trim tab led lights in solid white. Again I want to thank Dan at @lectrotabs for his patients and knowledge in answering all my questions.
The installation was very straight forward and no unexpected surprises. If I wasn't so anal/paranoid I think I could of had everything installed in about 3 to 4 hours but by over thinking thinks it took me about 8 hours to complete the install. I'm hoping that since I don't have to run any wiring in my boat, thanks to it being pre-wired and with deutsch connectors, that adding the other side connectors, plugging and play should only take an hour or so but if I was a betting man it will probably be closer to 2 to 3 hours.
Trim tabs modified for led's and assemble to check for fit.
I hope most of you aren't offended by what is hanging down between the trim tabs.
The trim tabs are installed, I would have liked to put them farther away from center but on my boat this is the only flat spot on the transom. The farther out you put the trim tabs the better they will control the roll of your boat which is one of the reasons I'm adding tabs.
Transom work is complete all that is left is the wiring.
Controller mounted on the dash with before and after pictures.
Before
After
Unfortunately I have run out of time, work is now consuming my time until late next week, got to love 12 hour shifts. I will post details and pictures once the wiring and water test is complete.
