What kind of tubing would you use to replace your inflator hose?
I would like to find a product to replace the hose on my Airhead inflator with a longer hose.
What type of hose would you recommend?
Flexible, light weight and around 3/4" diameter would be ideal.
zipper
Boston Whaler
I looked up hose for inflatable boats. Not as cheap as others I found but they are only 5-6' long. Bravo Pump Replacement Hose, Sold By the Foot
Thanks @zipper.
I suspect that those hoses are flexible PVC. That may be the best option since it is light weight and retains inner diameter through bends.
3/4 water hose seems like it could be good option as well.
Redneck_4Play
CONNECTICUT
I found a dishwasher drain hose at Lowes that I was able to use on mine. I don't recall the diameter but it's about 8 feet long and was able to modify it using the plastic tips from original hose so it can attach to pump.
tabbibus
Lake Lanier, GA
bruce please let us know what you get. My hose on that exact same pump broke last weekend!
@tabbibus, Airhead sells a replacement but it is sold out.
I believe this is the same hose. Mercury 889348 - HOSE-AIR PUMP | Boats.net
You likely can find a 3/4" or 7/8" dishwasher hose that will fit at a hardware store for a similar price to what is above.
I plan to install the pump in the bilge over the winter and hope to find a nicer hose to use next year.
BigAbe75
Litchfield, IL
I’ve got pics and a parts list in the doc in my signature. I’m just using some kind of clear plastic hose I found at the local farm store.
tdonoughue
The Woodlands, TX 77381
Hardware stores usually have sections of bulk hose, back by the plumbing. If you take in the existing hose I bet you can find something suitable and in whatever length you want (they usually cut it to your desired length).
