Norboo
- Fairfax Station, VA
- Limited S
What type of oil and brand do you use?
Sorry to get off topic, but how expensive is this?Mobil One. And I send it off to get analyzed by Blackstone labs. It's a cheap look into the internals of my engines.
X15Yamalube oem specs
25.00 for each engine but if you add TBN analysis that's another 10.00. the TBN number gives you the remaining protection factor in that oil. Telling you basically if it was still protecting your engine. If that number is low, then the oil doesn't have enough protection in it or you ran it too long. You really only have to do that once if you keep using that oil and changing at the same interval.Sorry to get off topic, but how expensive is this?
I do the same.Mobil One. And I send it off to get analyzed by Blackstone labs. It's a cheap look into the internals of my engines.
What would you do if it came back not good ?Mobil One. And I send it off to get analyzed by Blackstone labs. It's a cheap look into the internals of my engines.
