Drill holes. Don’t be scared. I can assure you if you sell the boat, that fire extinguisher won’t be moved.
that said, how accessible? Do you want it in a cubby? Under a seat cushion? Exposed?
You can buy some marine grade wood and make mounting boards. Buy longer SS bolts for things that bolt through and run them through the wood. Then bolt things to the wood.
Not exposed. I would like to put it in either the helm storage or the battery compartment.
That said, one trick I used was to look for other fittings when mounting things. For example, for my fuse box by the batteries, I recycled one of the bolts they use for the table bracket. Just took the nut off the back, added the box and bolted it with the same nut. Sometimes I replace the bolt with a longer one. I have used this technique to mount fire extinguishers and a host of other things.
I understand the want to not drill. But a fire extinguisher is important equipment that needs to be in the right place. Drill if needed.
But do get it mounted where it will be handy.
@Maineiac, It’s not clear to me why your dealer didn’t install two fire extinguishers (part of the safety equipment) on this brand new 2020 boat? Did you pay prep fees? If you did, head back and have them install two of them, if they give you grief, ask the heck did the prep fee cover? They are supposed to cover batteries, batt switches, fire extinguishers, etc. One will go behind the helm and the other in the battery compartment. You should also get a full tank of gas and if you didn’t, raise hell and ask for your prep fees back.
How short? I was thinking 3/4" stainless maybe but don't want it falling off after a hard bounce.
Anyone just use adhesives like JB weld or 3M?
