subysti
- Enfield CT
I am waiting for my second transducer and then I will mount them, I am having some stainless pieces made that will house the wires going through the hull that will be near water tight. Then use the 3M 5200 marine silicon to seal it all up. I am a little undecided as to which location I will mount the transducers. If you are in no hurry I will keep this site up to date with my progress to include pictures.Did you mount the transducer in the bottom of your hull or on the transom? If it's on the transom where did you drill through the hull and how did you seal the hole?
Where are people drilling the hole in the transom for an external transducer and how are they cealing the hole.
I installed a Lowrance Elite 5. Here are pics of the head unit as well as the transducer. All holes were sealed with 3M 4200 fast curing sealant. All nuts/bolts have blue Lok-tite on them. If you message me I'll be more than happy to help walk you through it.
Thank you for the pics, I am running into the issue of where to mount my transducer. Did mounting it to the bottom of the plate effect the performance of the boat? I want to do exactly the same mounting.I installed a Lowrance Elite 5. Here are pics of the head unit as well as the transducer. All holes were sealed with 3M 4200 fast curing sealant. All nuts/bolts have blue Lok-tite on them. If you message me I'll be more than happy to help walk you through it.
@AndyD That doesn't mess with your side scan? I have the total scan transducer that I need to mount. I like this idea and bought the flush mount kit just incase i needed it but now looking at your picture it looks like the scan would hit the keel pretty good. So I just wanted to make sure that all the features are working for you. Thanks!
@leizearmx what does your transducer look like? Can you send a pic of it?
