dan144k
- Palatine, IL
@Speedling
They sell instant water heaters which are also boilers, kind of an on demand system with a heat exchanger for the boiler system. and when you want hot water for faucet, it then stops water to the heat exchanger.
Also, some of the instant water heaters need special flue pipe, which can be very expensive. i would recomend a unit with pvc flu pipes.
Also they sell a valve kit for the instant units. it makes cleaning and testing much easier. basically it is a hose bib and main line ball valve combined in one assembly.
