XK Glow (Updated w/pictures)
Geiger41
Egg Harbor Township NJ
Has anyone ever used these products. There kits seem decent. You do not have to do any soldering and all connections and extensions between lights are by simply plugging each extension cord into another. Saving a lot time and hassle. Also if anyone is interested they have a 10percent off coupon code right now advertised on the sight.
www.xkglow.com
JC6275
Clifton IL.
LS
I used a motorcycle kit from them but not a boat kit. They were at a show giving really good discounts so I bought a kit.. they seemed to be good quality, I had them on for 2 seasons then sold the bike. I had no issues at all.
JC6275
Clifton IL.
LS
I had them on here, I went with them because of the multiple colors. They had the closest color to the teal color of my bike.IMG_21464008224585.jpeg
Geiger41
Project done !!!! No soldering just connect and run around the boat. Pictures to come tonight when they are on.
Geiger41
Here are a few pictures. I can have any color you could think of pretty much. I can make individual patterns. It comes preloaded with about 20 holiday color schemes. An android/ios app is available and its pretty damn good. Can go to the beat of music. Tons of other features. Bright as hell. Luckily there is a dim option
GiddYupJoe
Beavercreek, Ohio
Looks great! Which kit/package did you end up going with?
Geiger41
20pc iOS Android Million Color iPhone WiFi App Control 180 LED Marine Boat Neon Accent Light Kit - Xk Carbon Series
It came with 20 led strips that have connections of each end of the strip. Also came with a SHITLOAD or extension wires. Just snap the connections together and run the cords around the boat where you want them. It also comes with a few 1 into 2 splitters. I would recommend taking off your cushions off the inside walls of the boat, then you could just run the cords very easy. I did have to put a couple little wholes behind some of the cushions just to get to another area w/o seeing the wires. VERY easy job, just a little time consuming getting all the placements correct.
And by no means am I a handyman, but this was not bad at all.
OH YEAH, there also is a 10percent off code on there website right now.
txav8r
Lake Ray Roberts, Texas
Nicely done! How much were they? I think my custom lighting will cost me in the neighborhood of $50. It will be RGB but won't beat to the music unless I spend another $8 for a music controller. I have ordered a 4 zone controller that can control the 4 zones separately or together and that was an additional $75 but I want to try the tech out for what I am doing in the house too, but I may not end up using it in the boat or house, and will just sell it. It is a nice clean unit and can do plenty...it just may be more of what I don't want to do in the boat. I will be doing my 3rd set of LED's in a boat...I have been almost yelling that all of this light is WAY TOO MUCH LIGHT for several years. And I am about to do it again...at least this time, no speaker rings. I will do the cupholders, because I like the effect, and other indirect areas, but your are right, thank god for dimmers! Give us the particulars on your install, total cost with wire, connectors, extras trips to the depot, whatever.
Geiger41
Total price was $215.99. The controller can be up 2 zones. As far as particulars, EVERY piece of equipment/wire you need comes with the package. No additional wire is needed. Also you save tons of time not having to solder any connections. Tools needed for me were a drill, screwdriver, and painters tape. IF you want to hook the power directly to the battery then you will need a few feet of wire to run from the helm to the battery, if you are good with hooking up the power under the helm then you won't. No need for any extra trips to the store due tot he convenience and parts in the package
**Quicktip** Remove all the side cushions beforehand. This will allow you to simply run the wire/LED's very easily. Or you can simply tuck the access wire under these side cushions. (They will not come out due to vibration and bouncing)
txav8r
That is indeed a well put together system. Because I can tell you all that time soldering and piecing together is a royal PIA! But it is nice to configure exactly how you want it, instead of having to fit a system that is what it is into what you have. And your right about the extra trips to get this, or get that. I do like the wire ran behind the scenes, in loom, and tied appropriately, so that is an advantage I suppose to building your own, but this kit sure beats the hell out of the time and frustration equation! Nicely done!
Geiger41
Yeah the best thing is that there are so many different Y splitters along woth different connection cord lengths you can basically place the strips wherever you want on the boat. I am debating whether or not to get them all over the tower for 4th of July weekend
txav8r
I wanted to put lights on the bimini too, but mainly for dining and cleanup duties. Another zone! but it sure could be for festive occasions as well. But the lights under the bimini won't be seen from outside like on the tower.
jcyamaharider
Event Sponsor
Event Sponsor
Rosebud, Mo
Looks great!!
RightStuff
Twin Cities, Minnesota
Moomba
Looks great. Any chance you have a close-up of how you mounted some of the light strips?
BigN8
Corinth, TX
Is this system waterproof? Connections waterproof?
Geiger41
Ill get some pics soon. Here is the technical description:
What's Included:
  • - 3M tape & 3M promotor
  • - White wire clips
  • - Waterproof tape
  • - Zip ties
Tech Specs:
  • - Over 80ft(25m) WiFi connection.
  • - LED strips & pods are IP66 waterproof.
  • - light load capacity: Max 100pcs pods/strips.
  • - Currently compatible with iOS & Android device: iPhone, iPad, iPod Touch, Android phones
It says there is a 100 strip maximum...lmao I couldn't imagine having a 100 of these things running on anything let alone my boat after what 20 do for it
Geiger41
Pictures to come:
What's Included:
  • - Waterproof tape
  • - Zip ties
Tech Specs:
