Welcome to Jetboaters.net!
Water is coming up through the drain plug in storage locker when sitting. Anyone else experience this? If so, what was the cause and fix? FYI: All plugs are secured during operation.
Water in your bilge. The center of your boat is it's lowest point. The water won't pump out until you're in motion with the bow up, so the bilgewater flows to the stern. All your plugs should be in when the boat is in the water, not just during operation.
Thanks, I keep the plugs in 100% when in the water moving or sitting. Issue is, the water is pushing up seeping through the drain plug when it's closed. When I opened it to reseat the plug, water gushes up through the opening. Also, shouldn't the bilge pump water out when moving bow up? We went about 15 minutes straight before we anchored off to sit.
Sounds like something is amiss somewhere. Gushing up doesn't sound right out of the storage locker. I have left mine out to check it out and all day nothing came through. I leave mine in now as recommended, when I check them everything is dry. Bilge doesn't come on.
Check your hull and your engine compartment and rear bilge area. The hull for holes and the engine compartment and bilge for any water (like from a hose that came off). That much water means you have either a leak in a cooling line (or one is off) or a major hole somewhere.
It's being looked at tomorrow...hopefully. The engine compartment is bone dry. I am trying to find a schematic for the storage locker drain line to understand internal design. I am concerned with where the water is coming from.
Maybe it is coming in from the anchor locker hole? Then building up if there is a blockage which would create water pressure. Just a thought, and a shot in the dark.
There is no line that goes to the other side of that plug in the ski locker. That opens to the space between the 2 hulls. That is why I asked also about the bilge area in the back (below the cleanout ports). A lot of water can accumulate there between the 2 hulls before it fills and then gets up into the engine compartment (which is above the 2nd hull). So you may see water in the very aft of the boat which has not made it up to the level of engines. That may still be higher than the ski locker, so when you pull that ski locker plug, water will come up...
The fact that the water was not warm means it is probably not a cooling line (when there is water by the engine or below, we always ask the temp, as it tells from where the water is coming--engine or outside). That means a leak from the outside is most likely.
(the stock bilge pump is set in the engine bay, which is set in the 2nd hull. you can actually have a mess load of water in between the hulls before the bottom hull fills enough to get water up into the entrance to the engine compartment on most of our boats.)
So my dealer and Yamaha believe the water is coming in from the anchor locker drain. They believe water was filling the anchor locker enough (I don't buy it, never more than a little water in there at anytime). The fix was to install a stainless diverter over (that's what I am calling it, sorry) over the drain port to not allow the water to enter the locker. The dealer actually flooded the all hulls (boat on trailer) to find any possible leaks. No leaks. I am using the boat daily for the next four days and will monitor. Fingers crossed.
Could be the anchor locker drain, but that is an awful lot of water from that source to fill the hull enough to have water coming up into the ski locker. Be very careful when you take that out.
In favor of the dealer, tho, filling the boat like they did is the right first diagnostic...
Can you take a picture of the outside and inside of the anchor locker drain with this diverter installed ? I would like to see it.
Also the morons at Yamaha are sad. It has been documented here many times and resolved what it is, it is the fact that their anchor locker drain is a POS and doesn't go through all the way. Not hard to see that.
