HangOutdoors
- Royal Oak, MI
Everyone does understand that the interest rate is somewhat muted when you have fixed payoff plan. The rate is a huge factor that you get as long
as you amortize at the term you want to pay it off in and at the rate you want to pay, then adjust payments to compensate so they are hitting principal and in the end adjusting your APR, you can get awful close or actually under depending how aggressive you get.
None the less, @lgparra most likely cause the dealer gets juiced based on spread and rate from lending institution. So if you can upsell the rate you get a bigger cut at the dealer level. Or perhaps he just didn't know.
