- Rosebud, Mo
- 242X E-Series
We already make it for the 2015 and 2016 boats.Any timeline for this on a 2015 242LS?
I had a 210. You're going to run close to full throttle and 7-8k rpm with 1500 lbs at surf speed. Note that many boats, even dedicated wake boats, will run at 80% throttle or more when surfing. If I load our new boat up with its full 5000 pounds of ballast and have 5 or 6 full sized people on board, I'm running the engine pretty close to wide open as well, and that is a 6.2 V8.People with 210, what RPM are guys running doing surf with the wedge and like 1500pounds of ballast? If i need to cruise at 8000rpm to be able to surf ill pass and get another boat since it's almost full throttle
Thanks
If you want it change sides quickly it is best to purchase 2. If not, then you are in for an almost hour changeover.I just bought a 2008 AR230. This looks like a great product! Forgive me if I am repeating a question, but how difficult to change sides? I assume 2 ladder brackets would be required. How much for a second ladder bracket?
THANKS!
Sorry Loren, it will not.
