2023 195s 5/6mph loss
evosteve
195S
If it was impeller or wear ring your RPM's would be higher then before.
Thanks I appreciate that, wonder if dealer could figure it out and if it’s worth spending the money…or if it could deemed a warranty repair?
lazergeek
South Florida
Hmmm….feel like I’ve checked everything, not sure what to do other than buy the next bigger boat, lol
That's the biggest complaint for the 19 footers is it doesn't take much to kill your speed.
evosteve
195S
Well probably going to fix that and get a ‘24, 252 SE with the 1.9’s Hope that doesn’t have any issues losing speed after a year
F.M.
Decatur, AL
255XD
I know you said you already checked oil level. When you checked it, did you make sure the engines were level. I inadvertently slightly overfilled oil on my 242X a few years back and performance decreased dramatically. I checked the oil level several times to find that it was within range over the course of a week. It wasn’t until I put a level on top of the engines that I figured out it was overfilled.
Cobra Jet Steering LLC
Vendor
Florida
Also be sure the throttle is opening 100 percent in full throttle since they changed the cable and I have seen this happen with stale fuel also.
evosteve
195S
I have checked the and adjusted throttle cables.
Will look into intercooler issues if I can make the time in the next month or so.
