Mike Byrd
- X
Here are 3 video links to my engines running in a 2014 212X. One is for the port engine, starboard, and both running. This is with the boat on the lift without water attached. This is a freshwater boat since new.
It appears each engine is missing out at idle based on what I am seeing with the engine rocking/vibrating and the noise all happening together. I changed plugs with a backup set (low hour used) I had to see if there was a change. I did not see any difference.
Is it possible the idle is just a little too low? I ran Seafoam through it a tank of fuel ago. When on throttle, the boat performs flawlessly. The only other thing is it seems like I can smell the exhaust more from the helm when idling around but it could just be a coincidence.
Does anyone have any ideas? Both engines are behaving similarly. The noise seems to have gotten worse this year. I checked my buddy's 2016 212x and his engines purr like a sewing machine compared to this.
