1.8L Ribbon Delete, part numbers and information listed.
dan144k
Palatine, IL
Looking to do ribbon delete this year. Any vendors willing to put one together. people may also be interested in the flame arrestor filters. Just an idea.
Neutron
New Bern, NC
I would like to do this for my ar240 and also my FZS
swatski
North Caldwell, NJ
The RIVA intake kits are only like $40-50 a piece, but the filters are a lot more, maybe @ISLANDRACING can help.
FloJet
Moore, Oklahoma
Geez mine just came in the mail yesterday. Oh well, I'll eat this one I suppose. This is wrong thread but after I confirm all my led setup, I think the company I got them from would be interested in doing group buys. I will post up my truck and boat pics when all is completed.
swatski
North Caldwell, NJ
haknslash
Lake Martin, AL
Moomba
Is the sleeve really a must when removing the ribbon? I still need to remove mine, but I was wondering if anyone did any tests with and without a sleeve like RIVA makes to see if the performance is any different? I can certainly see from a flow efficient standpoint how a sleeve could improve airflow after removing the ribbon and rubber gasket but is it worth the price is my question?
blacksapphirez
Charleston, SC
SX195
you are DELETING something, you don't need to BUY anything!
blacksapphirez
Charleston, SC
SX195
Undo
remove
Done :)
blacksapphirez
Charleston, SC
SX195
my only guess is the turbulence it causes. if its smoother you may get better airflow but by how much? I'm content with 56mph :D
Neutron
New Bern, NC
I believe the sleeve that is used to replace the ribbon keeps the air flow smooth. Without it is turbulent.
dan144k
Palatine, IL
I read somewhere someone used a piece of pvc (smoothed the edges) to make there own sleve after they removed the ribbon.
haknslash
Lake Martin, AL
Moomba
I understand the sleeve. I'm just wondering if anyone tried a ribbon delete both without and with the sleeve and if there was a notable difference. For science!
Jaime
I will be doing this on my 242 Limited SE and post the results here.
d_coyne1984
Chanhassen, MN
I remember reading this too. The distortion temperature for PVC (<200 degrees F) is relatively low so using PVC makes me very nervous. Now it is probably very unlikely that where the sleeve sits that it gets that hot with the incoming air blowing over it, but I would definitely go out on the water, run your engine hard for a hour, and measure the the temperature of that area with a heat gun before trying to save $40 while risking a $10k engine rebuild if the PVC gets sucked in.
DO NOT ATTEMPT TO REINSTALL THE BLACK RUBBER BUSHING FROM THE FLAME ARRESTOR. There was a gentleman on here big enough to swallow his pride and shared the results of this destroying his engine.. I would hate to hear of this happening to someone else after this has already been tested.
swatski
North Caldwell, NJ
Actually the rubber bushing does go back in - around the RIVA new kit sleeve/ring, but yes it should not be reinstalled without the riva ring/kit. With the new kit it is fine.
haknslash
Lake Martin, AL
Moomba
Yea what the guy who grenaded his motor did was reinstall the rubber gasket by itself without the ribbon. It got sucked in the motor because nothing was preventing the gasket from collapsing and it puked itself.
You reuse the rubber gasket with the RIVA sleeve.
haknslash
Lake Martin, AL
Moomba
Crlos16
Houston TX
Interesting.
