Welcome to Jetboaters.net!
Looking to do ribbon delete this year. Any vendors willing to put one together. people may also be interested in the flame arrestor filters. Just an idea.
Geez mine just came in the mail yesterday. Oh well, I'll eat this one I suppose. This is wrong thread but after I confirm all my led setup, I think the company I got them from would be interested in doing group buys. I will post up my truck and boat pics when all is completed.
Is the sleeve really a must when removing the ribbon? I still need to remove mine, but I was wondering if anyone did any tests with and without a sleeve like RIVA makes to see if the performance is any different? I can certainly see from a flow efficient standpoint how a sleeve could improve airflow after removing the ribbon and rubber gasket but is it worth the price is my question?
I understand the sleeve. I'm just wondering if anyone tried a ribbon delete both without and with the sleeve and if there was a notable difference. For science!
I remember reading this too. The distortion temperature for PVC (<200 degrees F) is relatively low so using PVC makes me very nervous. Now it is probably very unlikely that where the sleeve sits that it gets that hot with the incoming air blowing over it, but I would definitely go out on the water, run your engine hard for a hour, and measure the the temperature of that area with a heat gun before trying to save $40 while risking a $10k engine rebuild if the PVC gets sucked in.
DO NOT ATTEMPT TO REINSTALL THE BLACK RUBBER BUSHING FROM THE FLAME ARRESTOR. There was a gentleman on here big enough to swallow his pride and shared the results of this destroying his engine.. I would hate to hear of this happening to someone else after this has already been tested.
Actually the rubber bushing does go back in - around the RIVA new kit sleeve/ring, but yes it should not be reinstalled without the riva ring/kit. With the new kit it is fine.
Yea what the guy who grenaded his motor did was reinstall the rubber gasket by itself without the ribbon. It got sucked in the motor because nothing was preventing the gasket from collapsing and it puked itself.
I would be down for a group buy as well. Isn't there a member on here who works for RIVA? Maybe they could see if they would be willing to do a group buy or forum discount code.
