19ft Transom bag order
jcyamaharider
Event Sponsor
Event Sponsor
Vendor
Rosebud, Mo
Would like to put together an order for 19ft bags and just want to know who wants one so I can order that amount. These would not be high sellers so I will not stock these all the time like 21ft and 24ft boats.
The bags are $325 and includes shipping and fittings. I can also sell the new 1700 GPH over the side pump for 150 shipped.
Let me know then we can arrange shipment.
I'll take one.
Do you need a pump also?
I have freemotion bags and pump. Is there an adapter to use my current pump?
Not sure.
I may be interested in one, do you make a wake wedge that would fit a 2014 AR192?
19ft boats do not need jet deflection.
image-jpeg.76908
I may be interested, I need you to get me hooked on surfing while at Shelbyville first.
The challenge will be getting me up on a surf board. I've never done it before, I love wakeboarding and always wanted to try surfing but never had the opportunity.
If you can wake board then getting up on a surf board will be second hand nature.
What kind of lead time are we talking for this bag?
1-2 weeks roughly
I want one, and also need a pump but want to buy the straight line 4250 gph pump to speed things up. Is that pump able to work with this bag?
I only tried wake boarding once 10 plus years ago and never could get up. Then I found snowboarding and spend 50 plus days a year in the mountains. Fast forward to two weeks ago and it took me all of 5 min to learn to get up on a surfboard. It's super easy and so much fun it's crazy.
I'm not certain but see my post #6 above. @Bill D do you know if that connector would work for the two pump styles?
You're not going to get much advantage with that pump on the fatsac bag. That pump is made to work with the 1.5" port on the sumo max bag and that's where the super high flow rates come in. Even if you could hook that pump to a 3/4" port on the fatsac bag, you're cutting your flow in half, and you might be slightly faster than a tsunami pump, but not significantly so, I don't believe.
^^^That's one thing about those bags that would be nice to change, currently the quick connect ports used (all of them!) are small ID (3/4"?)
Nominal volume ratings on ballast pumps, especially aerator type, does not mean much once those things are factored in.
So then about 15 min or so to fill with the tsunami pump?
