Bluejuice
- Other
So I've been reading for hours and thanks to all who have contributed. I have a 2004 sr230, less than 170hrs on each engine, original engines. Port has fuel in oil. Been reading, seem it's the injector or the ecu, or the ecu BECAUSE of a bad injector. I ran YDS. All good on starboard side, it ran the injector test just fine. BUT on the port engine, I get the following error:
Engine is running or the throttle is too open.Test again after turning engine off or closing valve.
BUT, the engine IS off. I don't know what valve they mean but all throttle body valves are closed. I tried and tried moving the throttle and the valves but nothing helped. So because if this I can't test the injectors with YDS.
I am assuming this means a bad ECU, which means, according to what I've read, i need to send it off to Chico , CA.
I still need to pull the ECU and check it out for water etc., and I will pull the fuel rail and test the injectors, maybe this weekend. But I was just wondering if anyone has experienced this error in YDS.
Thanks everyone.
Roy
Thanks everyone.
Roy
