cybuch
- Gilbert, az
I found mine on eBay. It is a non ho (vx 110) equivalent. There was at least 6 guys with short blocks without the gear reduction, oil cooler and without the heads for under $1k. But they looked a bit used and abused. I did find a couple of engines that were fresh water/low hours that were more complete in the 2k range. Mine was without oil cooler, but complete from the exhaust manifold to the gear reduction. So it had never been torn into. I just had to add my oil cooler, the rest of my exhaust and intake/fuel injection and it was good to go.@itsdgm , where did you find a used one? The last time I bought the FXHO and pulled that motor. Then I had mine rebuilt and put it back into the FXHO. I don't want to go that path again, don't need 2 jet skis and a boat. Lol.
Ok, good to know. It's quite possible that mine was cracked all along and didn't get bad enough to notice until I had the stuck valve issue.Gotcha, I will do a bit of searching. No, this motor has never had any issues at all. Never tore into it, but I am not the original owner.
I built a gantry and used a chain hoist. I have removed and reinstalled the engine four times now and have it down to about 3 hours to remove and the same to install.I'm in a similar situation. '04 ar230 with bad compassion on 2 and 3, milkshake oil. What is the procedure to pull the engine? Can I do it alone? I have a cherry picker, but I'm not sure it goes high enough. What all did you remove before you pulled it. Mine is down to the valve cover, but I prefer working on it in my shop. I'm hoping mine is just the hg and not cracked.
Only weighs a couple hundred pounds max. Looking at @cybuch pics you won't have as high of a lift. My boat requires me to lift the engine out high enough to clear the rear seats, but it looks like that seat comes out with the engine cover.Damn. I was going there was an easy way I was missing. For the amount of effort buying it building a crane would take, I'm hoping to be done. What's it weigh? I wonder if I could weld an extension on my hf 2 ton picker.
Off topic, but I like the mini split in your garage. I need one!I can pull it in about an hour by myself. Of course I am all setup for it and its way easier in a ar230. The only thing I need help with is removing the engine cover. Here is my setup.
Wow!! Sorry to hear that.Well, motor is out and I think I found my problem, cracked case. Not only am I getting water in the oil, but I am also getting water coming out of the case. I guess a call to SBT for a new motor.
Can you describe where exactly this crack is, or take a picture from father back? Could I see it with the engine in the boat?Well, motor is out and I think I found my problem, cracked case. Not only am I getting water in the oil, but I am also getting water coming out of the case. I guess a call to SBT for a new motor.
