2015 212x sub location
duffell_shawnee
Shawnee, OK
Looking for input/recommendations for potential locations for a 10" sub in a 2015 212x. Install expected to take place later this week. Any thoughts?
Master-Spud
Plamondon, Alberta, Canada
Nautique
Picking mine up for the installers today, I'll snap some picks... You planning on infinite baffle sub? Or putting it in a box?
duffell_shawnee
Shawnee, OK
Infinite baffle. Looking forward to your photos. Looking at a JL M700 and the JL MX10 sub. Will swap factory polks if necessary if amplification doesn't help enough.
duffell_shawnee
Shawnee, OK
Does the factory Clarion head unit have the capability to control the sub level or did you add the separate switch?
octavio3311
Brookfield, Ct
Right behind the captains seat is where I put mine!
veedubtek
Punta Gorda, FL
Scout
Ditto. x2. Even though I didn't want to and everyone kept saying that was the best spot. Low and behold, they were right! And the cooler still fits.
ShesCrafty
Webster Groves, Missouri
I just played with the backside of that Clarion head unit, wiring in a Kicker Hideaway (port side). If you run your amp off the non-fading pre-amp outs (purple and purple/white) you will have some ability to control the signal level from the head unit (sub level). You may still want your separate switch, though.
Also, in my 212x, the blue/white remote power wire from the Clarion was bundled in with all the line level amped connections - as if it were connected to something. After scratching my head for an hour, I went ahead and clipped it and wired it to my amplified sub. It didn't cut power to anything. Hope this helps.
duffell_shawnee
Shawnee, OK
Thanks for the info. Not brave enough to tackle myself but will definitely share with my stereo guy. Looking forward to the upgrade!
ShesCrafty
If he finds that 'remote' wire is actually powering something, let me know! ;)
Also, your guy will want to remove the bow back cushion, starboard side to access the back of the dash/head unit. You have to reach up behind from the storage area below and find three wing nuts to remove the cushion back, then carefully lift/wiggle it off. There's an open access hole behind it.
Geiger41
Egg Harbor Township NJ
When your done with the install get ahold of me, I have some great setting on your HU for those subs to ROCK even more then when you get it back from the installer, unless he already knows lol
duffell_shawnee
Shawnee, OK
He showed me a setting in the HU to adjust but would love to know if there's something else I could do. He mentioned something about the sub needing to "break in" and then I could really turn up the setting if I wanted. Does that sound right? Finally got the JL tower speakers in this week and getting them installed next week.
Geiger41
When Im back at the boat ill find it....i think its called "MX" or something like that...turn that on then tweak
