2017 clean out plugs
UpNorth
Waconia, MN
I took the clean out plugs out of my ‘17 AR240 today to put some lube on them. I could not for the life of me get the starboard plug to lock again.
I was on the water while doing this and the boat stays in the water during the summer.
While searching the forum for tips it appears the tips/suggestions are for the ‘16 and older plugs.
Any help will be appreciated.
Thanks
Sbrown
Easton, Pa
The plugs can get turned while you have them out. Make sure the key on the rim of the plug is lined up to the notch in the plug tube and the handles are turned all the way counter clockwise before you insert the plugs into the tubes
Weeb
Denver NC 28037
The rubber must be swollen. Get a repair kit. If what @Sbrown stated has been done correctly.
it happened to me from leaving the plugs in. Now I’m on a lift and pull them every time and haven’t had an issue.
Troy JK
I pull mine after every use Because They always have a few inches of water sitting on top of them.
then I usually spray WD40 or the xps before going back in.
UpNorth
Waconia, MN
It was set up right. The “set” notch was in the correct slot and lined up appropriately.
UpNorth
Waconia, MN
This sounds like it could be the culprit. It seemed like it needed to sink about another 1/8”.
Where did you get a repair kit for the ‘17 and newer plugs?
I looked and only see the previous generation plug rebuild kits
UpNorth
Waconia, MN
I think I will be doing this once this thorn is out of my side.
BRenouf
Moncton, NB, Canada
Limited
Hi all,
My 2010 242 Limited has the same problems as I hear on the form from many boater. A lot of info to take in for sure. I see from the Yamaha web site for boat parts that the repair kit is shown on the breakdown of the Jet Unit 4. It is not shown on earlier makes.
My question is: Does anyone know if it is a problem to take the clean out apart and fit the repair kit? As my 2010 was not listed in the Fitment models on Partzilla's web site, I asked them and they said I would have to buy the complete unit??
Perhaps I should just order it from another supplier and not worry. Any comments from those who have changed it out on older than 2012?
Cambo
Long Island
2017 had them updated they twist in older models have a handle that pushes down. I'm not sure about the repair kits but annually on both types I have used red scotch brite to scrub off oxidation and build up in the tunnel aluminum to allow the clean out plugs to go in easier.
