2018 210 FSH Sport T-Top Fishing Rod Grommets
Mike Courterier
Has anyone sourced the black 2-part grommets for the fishing rod pass throughs on the T-Top cover?
I lost one in transit and would like to pick up a couple.
Liveto99
New York Hudson Valley
I lost one also. If I get to the hardtop I’ll send u the ones I have.
Mike Courterier
Thanks Frank... you got me headed in the right direction!
I ended up getting these from Amazon... the description does not match the image measurements but for $8.99 and free shipping I figured I'd give them a go.
Selling Wonderful 1-9/16-Inch Inner Diameter Plastic Curtain Grommets 20-Pack (Black): Amazon.com: Industrial & Scientific
Liveto99, if they work out I'll send you a couple.
Skibum7
FSH Deluxe
I know this thread is two years old, but does anyone have some reviews for these grommets? I'm missing a few on my FSH T-Top and I'm wondering if the Amazon ones worked, versus paying extra for the Grommetmart brand.
vesder21
Cleveland Ohio
sa
Same, I need 2 and my boat is a 2020!!!
I wished they would have used some stronger adhesive or bolted them together!!!!
bccomstock
sa
Ditto. I need all three for one side for some reason.
bccomstock
I ended up buying the Amazon 20 pack for $10 but haven’t put them on yet. Thinking I’ll replace all of them to make them all match again.
zipper
Boston Whaler
I don't have a FSH. Are they plastic grommets? No wonder. Or brass? Brass will need a press to install, but they will not disappear from the boat. 2" brass, nickel or black from Sailrite, but you also need the press.
With all of the missing grommets above, someone could set up a quick repair service if they had a press.
bccomstock
The Amazon ones I ordered are plastic. I’ll probably glue them with some adhesive like Frank mentioned below.
Mike Courterier
@Frank Marshall or @Mike Courterier .. any luck with the replacement ones you ordered?
Sorry for the delay in responding... yes, the ones I ordered from Amazon fit perfectly. The only difference is that the inner ring is white instead of black, but unless you are really looking you can't see it from below. I have replaced 2 of my 6 so far and have 8 remaining as spares.
bccomstock
No problem! I got those as well and noticed the white ring on the inside. Not a big deal to me. I’ll probably just replace all of them since I got a 20 pack.
vesder21
Cleveland Ohio
does anyone want to stick 2 in an envelope and mail me a set? I can Venmo or PP you a few bucks?
bccomstock
I’m out of town for the rest of the week but I can next week if someone else doesn’t
bccomstock
I replaced the 3 I was missing and swapped out the originals on the other side. So I have 3 originals and plenty of the Amazon version. Let me know which you’d want and PM me your address and I’ll send some your way.
