CoastalBoater
- 242 Limited S E-Series
Hello all,
I have been reading these forums for a while, but first post.
I was looking at buying a 2018 242SE offered by a second owner at a discount with some corrosion issues particularly on tower/bimini frame and also noticeable on the stern ladder. I had it sent to a dealer for inspection and the motors checked out OK with the ECUs reading 75 hours (the Connext says 58 and 35 hours so the dealer updated and fixed the software.) They also found that one pump had a problem and was making noise. I have not seen the full report yet but from what they described it is the impeller hitting the housing. They are correcting this for the owner and waiting on the parts. My concern is that it seems very early for this kind of issue with the impeller housing swelling from corrosion? I am now concerned that this boat was moored in salt water. The trailer was added by the second owner. Although the interior and upholstery look good as it was covered, I am concerned about more issues coming up and thinking I should pass on this one. Tough to swallow given the low supply but I guess it does not do me any good if it is potentially in the shop more than in use. Does this sound out of the ordinary?
Thanks in advance and also for all of your knowledge I was able to glean from previous posts.
