Ian Andrews
- Calgary Ab
- AR195
1st of a number of reviews. Here is the link:
That's a good question!I'm confused how the flush hook up works since the motor shuts off when the hatch is open??
But, the wet storage area now has large drain channels at each end of the storage area. My guess is they simply have you lay the hose in that channel, then close the hatch.
Sam - That's important to know. Do you mean all years with superchargers?
Some people say so BUT the manual clearly says that the minimum octane fuel you should use is 91 and that low-octane gasoline "can seriously damage the engine." That's for 2018. The 2019 manual is not out yet.So if needed you can run 87 octane in a 195 without damaging anything and only take a performance hit?
Can I ask what brand? Is it safe for our engines? Thinking of trying.
There's a channel on the side where you run the hose, a little weird, but I guess it works...I'm confused how the flush hook up works since the motor shuts off when the hatch is open??
