  • JetBoaters.Net 2nd Annual SeaDoo Switch Group Buy Sponsored By JetBoatPilot Is Live Now. Save 25% Off Select SeaDoo Switch Gear through October 31st.
    Click Here to go to the Jetboatpilot Seadoo Group buy
    You can delete this notice with the "X" in the upper right>>>
2019 AR195 steering wheel indexing options
Craigmc
Ok so I need ideas on how to mark my steering wheel position when it’s at top dead center, I never know if it’s straight or turned left or right?
many ideas or build thread are appreciated.
First disconnect the nozzle from the cable where it attaches and has adjustment capabilities then turn the wheel all the way to the right and place a piece of tape on top. Now turn the wheel all the way to the left and place a piece of tape on top , now rotate the wheel back in the opposite direction so that both pieces of tape are evenly pointed to the floor and place a piece of tape on top , that is center it should be very close to a wheel spoke pointing down as well. Now have the nozzle straight and adjust the cable so it is able to be reattached, you now have the wheel centered get a sticker or some colored tape and place it somewhere on the wheel for you to recognize when the wheel is centered. I find a lot of wheels not centered properly from the factory and this can cause issues with the boat turning one way a lot better that the other if the nozzle is not centered correctly.
Yup! just like Cobra stated. This is how we do it as well.
