2020 Yamaha 195S
tiagoweiler
Hi, I am having issues removing the impeller from the shaft. I have purchased a solas impeller to see if the cavitation problem I have gets solved but I am not able to remove the old one. Don’t want to force it more as I am afraid that the shaft could get bended. Tried to purchase a new one but it is in back order, anyone could recommend where I can get a new or a working used one? Part number is 6GN-45511-00-00.
Thanks!
Thanks!
Do a search for @Hoyt, he has a long build thread including changing his impeller on the same model.
It should help you.
Take it to a dealer and have them do it save yourself a lot of anguish . And hope it does not get a fracture in it that later grows and fails ,, I just cut the impeller and split the hub to save the drive shaft from exces torque , some people drive over it with a wrench attached for real! Do a search and you will understand the trouble it is to get one off .
