Neutron
- New Bern, NC
I will be installing it on Sunday, i only dry fitted it so far.How was the fit?
@JetBoatPilot I have a 2022 AR210. They are not listed on the site…does the 2021 AR210 fit exactly?
Thanks @HangOutdoors and your installation thread is going to be very helpful!No change in boat on the AR210's
Did you only fill in the holes that were exposed or all of the snap holes? Did you fill them in after you laid the SeaDek or before?Recommend using Spectrum Gel Coat Patch to fill snap holes and light sand rather than 5200. Looks professional and definitely much better if the seadek doesn't cover some snaps, like it does on my boat. Order it now so you have it when your SeaDek comes in. It takes 2-4 weeks minimum depending on their volume from spectrum.
Yes for sure!@JetBoatPilot I have a 2022 AR210. They are not listed on the site…does the 2021 AR210 fit exactly?
Thank you!! Just ordered the Gel Patch for the snap holes. I couldn't find the blue we needed to try and also fix some dings under the boat.PREP IS EVERYTHING
- I removed the Carpet/Existing Stuff.
- Washed entire floor and surfaces getting the SeaDek with Dishwashing soap, Mild and hot water.
- Scrubbed by hand the channels around the gas tank.
- Rinsed out the boat.
- Used my Leaf Blower to dry out entire floor and surface areas getting SeaDek.
- Removed all Snaps by Unscrewing.
- Any chipping around snaps I dug out.
- Filled all snap holes (and a gouge) with Spectrum Gel Patch (mixed a small bit and used that and then mixed more). put a bit more so it is slightly higher than surrounding area and sand down flush. You may need to do a small second application on a couple with just a smidge. You want to do this before seadek cause you will sand. Dries in a couple hours or less. I filled all holes in entire boat even those being covered with the Gel Patch. Figured I would go the extra mile.
- Used my small Dewalt orbital sander to knock down some of the high points on the patches
- Finished hand sanding with 800 then 1000 grit sandpaper. Can't tell there were snaps.
- Wiped all patches and got up sanding dust with Acetone.
- Test fit a piece at front of boat floor and started there working back toward stern.
- Once I eyeballed where it was going I used a grease pencil to mark a couple of edges for reference so I could line it up when doing the final fit.
- I cleaned the area under each piece with Acetone Liberally.
- OPTIONAL - Used 3M Adhesive Primer then at let it set up for a few minutes. I did this, some do not , personal preference.
- Scored the piece going down on the brown paper back. DO NOT CUT THE SEADEK
- Pulled 2 inches on either side of the score and folded them back. Then they will roll back a bit so you can set the seadek down on floor/surface with the peeled paper keeping it up off the surface a bit so you can position it.
- Once lined up to my marks i put above I would push down and let it stick in the center then peel and do the right side slowly while sticking then the left so there were no air bubbles.
- Then I would stand it and move to the next piece.
- Make sure your lines are lined up on SeaDek, you may want to test fit a couple of pieces.
They were very helpful. They had 3 blue's listed under our boat so I ended up having to call Yamaha to get the color number and then call them back. It is now ordered as well. Thanks for all the help!!Call up Spectrum on the phone, they will take care of you. Very helpful and will get you the exact match.
How do I order this for my AR210? What font options are available?Sure here you go.View attachment 163851
