I thought I saw someone mention a special price for those who purchased Thrust Vector Wake and now considering upgrading to the new Thrust Vectors. Can someone confirm if that is correct?
That is our Thrust Vector Upgrade Program. You get 50% off the new Thrust Vector system when you return your old Thrust Vector Wake system. Call us at 850-867-1410 to inquire.
Has there been anything published on how to convert from TVW to the new TV? I remember when installing the TVW system I had to epoxy something on to the boat and wondering if that is something that would need to be removed when making this change.
Installed my Trust Vectors today. Pretty easy install. Took about 1.75 hr including cleanup. I can't for the wife to try it out!. One thing not included in the instructions is to clean the mating surfaces for the anode with a wire brush. It is important to make good electrical contact. I also added the the access port riser while I was at it. Thanks Will Owen and Jetboatpilot! Class act.
I received my TV super fast and just in time to install on my new 21' FSH 195 Sport I picked up Thursday. Small question though, it looks like it came with the older right side spring/screw/washer/sleeve setup before the addendum(according to the install video). I installed it, but I like the newer style the places a washer inbetween the bucket and the spring.
Haven't seen much on the wake shaper for the 21 foot boats. Is the shaper and new TVs replacing the TVWs? Is the wake shaper a competitor to Yamahas wake booster? Can we expect a new video soon as well? Thanks Will!
I want in! 2018 242X e-series. I have not decided if I want just TV or both, and want to confirm total$. When I get a confirm reply that Im in here I will call the office. Thank You!!!!
Yes you do, this is not the exact ones from factory (just found pic online) but its the 2 hole pointing to the side so that when your bucket is down, it direct jet thrust sideways.
Here's a picture of the factory reverse outlet which provides more of a lateral style reverse flow than 2018 and prior nozzles. It's not completely lateral but it is much better than the previous generation.
UPDATE! THRUST VECTOR AND LATERAL THRUSTER ARE SELLING AT MAXIMUM 30% DISCOUNT! SHIPMENTS ARE GOING OUT DAILY. GET YOURS AT OUR BEST PRICE OF THE YEAR BEFORE THIS EVENT IS OVER (AUG 31).
Yes you do, this is not the exact ones from factory (just found pic online) but its the 2 hole pointing to the side so that when your bucket is down, it direct jet thrust sideways. View attachment 160913
Huh....who knew! And here I was wondering what all the fuss was about with regard to slow speed handling, as I got the hang of it almost immediately last year when driving her for the first time! Thanks for sharing!!!
Here's a picture of the factory reverse outlet which provides more of a lateral style reverse flow than 2018 and prior nozzles. It's not completely lateral but it is much better than the previous generation. View attachment 160914
