2021 Scarab 165 ground for garmin echo plus
Bseltzer4
165 ID
Hello friends,
I’m trying to find out where I can pick up a ground on my scarab 165. Prefer to use one by fuse panel behind console behind access panel inside boat toward bow. There is a plastic access door. Inside is fuse block for 12 volt accessories and about 10 other fuses. I am going to tie in 12 volt wire for garmin but need a ground. Thank you
