swatski
- North Caldwell, NJ
Propeller (impeller) shaft in these boats is basically an extension of the crankshaft, no gear box like o/b, or gear reduction like MR1s; if shaft vibrations are bad enough (beyond what the damper can absorb?) it seems to destroy those motors. It's strange but it happens.Could somebody or maybe @Yamaha describe how bad alignment/harmonics (or whatever) could cause the engine damage after the driveshaft was replaced?
In this regard, there have been documented examples of failed main pump bearings leading to blown 1.8s.
