GTBRMC
- Waukesha, WI
- Boatless
- SX
If anyone gets this fixed for me it’s more than a bottle! The repair is $20k. All I want is the boat fixed even if I pay so I can get back on the water. I cannot believe that a company as good as Yamaha is leaving situation like this dangling. I literally cannot get through to them. The manager of The dealer finally spoke with someone there and is trying to accelerate the parts. But I guess them covering it is off the table. Bad karma for them. If I ran my business this way I would get a bad reputation. I do have access to good lawyers and if I miss the summer I will go for “lemon” approach. In the meanwhile hopefully they get me back on the water. The longer the repair delayed the more upset I am getting. Boat defect and no parts to fix it even if a customer willing to pay. That’s called a “no boat trap”.
As has been mentioned a couple of times, the shaft failure looks like a metallurgical issue - a seam in the bar used to produce it, improper heat treat, or similar. A qualified metallurgical analysis will likely show what the issue / failure mode was. This would be done through a standard physical examination of the parts (the piece that broke off would be FAR easier to examine in a lab - obviously). The analysis would likely be definitive. Assuming it is a metallurgical problem, such an analysis would clearly show defect(s) in material and/or workmanship. Such analyses are done all of the time and frequently are used as evidence in court.
The facts reside in the metal pieces. And your best bet to get a favorable resolution, IMO, is to demonstrate to Yamaha factual evidence of material and/or workmanship defect. Good luck.
