252SE questions
ChrisTurbo
252SE
Hey all,
Just picked up my new 252SE last weekend and noticed a couple things.
1. I had a bit of brake fluid leak out of the trailer tongue onto my driveway when I first parked it. I'm hoping it was only overfilled as I was sloped a little downhill. Anyone else ever have this problem?
2. I turned on both house and start batteries to fire up the radio and noticed I had no bass. Turned up the volume about halfway as to not upset the neighbors and there was no vibration coming from the cone of the factory 10" sub. I did check the 'zone control' to make sure the sub volume was all the way up. Any thoughts? Do the engines have to be running ..not sure if Yamaha shuts off the sub when there is no running charge to the batteries.
I'm sure I'll have more questions once I really start going thru this thing out on the water so I wanted to start my own thread. Any feedback is appreciated!
Khalid
255XE
Hi Chris,
I recently had a similar issue with my system. When it was on the trailer, the entire system sounded terrible and the sub wasn’t working at all (All 4 batteries were fully charged). I spent a lot of time trouble shooting it with a friend. The sub wasn’t firing even after we connected it to amp ports that were pushing the 10” tower speakers. So, we came to the conclusion that the sub had died and I ordered a replacement.
Comes the weekend with its 90 degree weather and took the boat out to the lake. To my surprise (pleasant), the entire system was working perfectly, even when floating on the beach. This is the 1st season something like this happens. So, I am not sure what it could be.
In summary, I suggest running the boat first before investing a lot of time and money into trouble shooting / repairs / upgrades
Good luck and please let me know how it goes
Khalid
1WetBoat
Tampa
Hey all,
Mine dripped out a little bit, seems to have been overfilled. It doesn't do it anymore and i have checked the level several times.
Hurly23
Orting, Wa
252SE
Hey all,
SWEET BOAT!! :)
I am having the same issue with my stereo system on my 252SE since I bought it back in Oct. Sub doesnt work, and the speakers sound weak. Seems like theyre not getting powered by the amp for some reason. The Amp light is on, so I know it has power, but nothing from the sub, and the speakers sound like my old '91 Chevy Llumina speakers.
I have tried both on land, and on water with engines running....No dice.
The dealer said I can bring it in for my 10 hr, and they will figure it out. I think there is something wrong with the either the connections from the amp, or internal to the amp.
Let me know if yours works when you take it out to the water, or if you get it figured out.
Prasolot
252SD
Same issue with my new 252sd - sub not working right from the beginning. Dealer called Yamaha to find out that there is an amplifier update needed and needs to be done by Wetsound. Dealer removed the amp and ship it to them for update. All process about 1 week long with reinstallation. Unfortunately right after I had problems with my batteries being discharged really fast. Dealer told me that they didn't found anything wrong but its fixed now🤔 Going to check this weekend...
AmesJainchill
Harrison Twp, MI
I had the same symptoms with my factory stereo when I first got it - granted a 2019, so maybe a different Fusion head unit? No bass and crap sound (to my ears). The controls from the connext screen suck for setting up the system. I only use them at the helm for selecting source, dialing volume or choosing mp3 tracks from the usb key. The solution for me was to use the head unit controls from the swim platform to do the setup. Then I was able to dial in the sub, zone control, treble/bass, etc. from there. Head unit firmware can be updated from there as well. Has worked great since! Hopefully that solves at least some folks' initial experience. 👍
Prasolot
252SD
What sucks, there is no treble, bass... adjustments on the screen or swim platform for my boat, just source and zone control. I guess they eliminated it for some reason on 2021 models
jocolo21
252SE
Plain and simple yamaha screw us with controlling the gains and sound output from the yamaha spec'ed ws amp. At least on the 2019 you had a eq sstting, not so on the 252, i ditch everything but the stock sub, and installed an all jl system. A cheaper route would be to ditch the stock amp and buy an amp to power your system that you can actually adjust, just remember your cockpit speaker and the bow are wired together, and your swimplatform speakers are on a separate ch.
Prasolot
252SD
Did you get the speakers with led rings? Which JL system and what was a cost if you don't mind telling me? Audio definitely sucks so I'm planning to upgrade shortly
ugamarkj
252SD
Speakers on my 252SD are awful. Already had two speakers replaced under warranty. Now the entire left side crackles to the point where I just turn off the music entirely. Later the left side speakers just started buzzing with the volume completely off. Haven't even checked the sub, but wouldn't be surprised if it doesn't work either.
adrianp89
Tampa Bay, FL
252SE
I get tons of compliments on mine. Crazy how it is hit or miss.
jocolo21
252SE
2 × JL Audio M3-650X-S-Gm-i - M3 6.5" Marine Coaxial Speakers (pair) - LED Gunmetal Sport Grilles
$299pr
jocolo21
252SE
how loud do you listen to your music? the sound comes out drowned with no real bass hi or mid, its middle of the road at most. Sorry just my 2 cents, i like to listen to different genres and like deep bass from my system, theres none on the stock system,
adrianp89
Tampa Bay, FL
252SE
I’ve had it a full blast, I’m a professional installer and the sub is extremely impressive. There is certainly no lack of bass across any genre. I have a feeling it’s an issue with the software on the amp. We saw this quite often with FCA Harmon Kardon systems. One sounds great, one sounds like a 70s stereo system with a single speaker.
jocolo21
252SE
lucky bro, my 2019 242 and 252se sucked both, yes there is a problem with the yamaha software and yamaha trying to control the way we listen to music
scbruet
Charlotte
252SE
I just noticed the same as well. I got mine back in October, but I only used it a few times and I'm sure the sub has never worked. Calling my dealer today to see what they say.
ChrisTurbo
252SE
Let me know what your dealer says ...mine just said they'll look at it next time I bring it in for service but that won't be for a while and I'd like for it to be fixed sooner rather than later.
