paulthepilot
- 252SE
Got our 252SE last year in November after finally finding one. Amazing boat coming from a 2013 242 Limited.
Finally put it in the water a month later and when we took it out and pulled the plug, there was quit a bit of water that came out of it after only being out for 45 minutes. This already had us a little suspicious because the 242 was dry as can be.
Finally got it out to havasu this weekend and holy crap. This boat will not stop taking on water. The bilge pump is running basically 24/7. We thought it was the front cooler plug because when I looked inside the 2 pieces were not connected so i plugged it up, but that wasn't it.
After being out for about 2 hours on the first day I pulled it out of the water and there was a 40 second stream of water coming out of the drain plug, mind you, again after running the bilge 3 times during that where it spit out water for about 15 seconds.
Then the second day we left it in for 3 days total and every morning we got to it, the bilge would run for over 30 seconds just pissing on the dock. The boat is taking on water even sitting at the dock without being moved.....
When we got home today we took a look underneath. One of the screws for the intake grate was completely out. Couple more miles and it would have just fallen out. but we don't believe that was it. Then we looked at the other engine and they installed it sideways. The grate and the engine itself are actually overlapping and they still installed it that way. No locktite on any of the bolts on the bottom.
The weirdest part? Only the bottom hull is filling up. The engine area stays almost completely dry unless it sat overnight then there is usually a tiny bit of water in it.
To us this is completely disgusting to be selling a 80k boat and have this many issues with it taking on water. Im hoping that yamaha support will help us when I call them tomorrow because every boat shop is busy as can be right now, but I should also be having my boat on the water when it is brand new and not sitting in a shop, or sinking for that matter.
Just wanted to write this up for you guys that bought a new 252. Just keep looking for little indications of water somewhere.
If anyone has any other means of getting a hold of someone at Yamaha, it would be greatly appreciated!!
