- Royal, AR
- SX
My opinion is that not having access to the wall from the outside may make it more difficult but it should be possible to build the header from the inside regardless of what brick is in place. There should be a gap between the brick and the framing. So you should be able to frame inside without disturbing the brick.
Here are some pictures of my garage door headers. They are way more than what you would need. I have two stories of brick (22 feet) over the garage doors. My headers are three 12" LVLs with a 2x12 added to the inside to fill the gap. Then I lag bolted a piece of 4"x6" angle to the outside for a brick lentil. The 6" side is up for greater strength. I believe there are four 2x8s vertically supporting each end of each header. The 2x8s are tucked inside the 8.25" SIP panels that make up my walls. When looking at these remember that there is an air gap of several inches between the framing and the brick.
