shaddad
- Other
- SX
After a month of trying to contact them, I finally got an email response from Alumacraft. I was correct, something serious has happened there: They’ve been HACKED! I received an email yesterday (9/1/22) with the following text:
“Please accept our apology for the delayed response. BRP has been a victim of an external cybersecurity attack resulting in a companywide system shut down during the recovery period. Currently many systems (including the phone lines) are still not accessible for teams within the company.”
On about 8/24/22, I posted that I think I may have water between my hull and my deck because the boat appears to weigh 485 pounds more than it should, based on the weight listed in the boat specs. Here is what Alumacraft said about that:
“As stated before he only information they could provide is the following.
It's really hard to find an area to check to see if the foam is saturated with water. It does happen. Once water gets into the foamed area if it can drain and isn't trapped. The bilge pump will pump the water out once it reaches the back of the boat.”
As you can imagine, I am not very happy with that response since it is of no help. Today, I drilled a hole in the deck with a 1 ½ inch hole saw. As I suspected, the foam is saturated with water.
I tried, once again, to call Alumacraft for guidance. Their customer service number is still disconnected. Their main number has an option for customers, but when you push that button you get a recording that tells you to send them a letter or an email. Color me ticked off!
I believe I have 2 options: 1) Using my hole saw, drill a number of holes in the deck and use a dehumidifier to try to dry out the area under the deck. 2) Use a skill saw to cut out and remove the entire deck (it is welded on). Obviously, #1 is much less radical, but I am not sure it will work. It will be tricky to cut out the entire deck without cutting into the cross supports which lie directly under the deck. With either option, I will have to do some substantial repair work to finish the job. I am thinking PC7 to replace the holes or glue the deck back, on depending whether I choose option 1 or 2.
I could use some suggestions from members of this board. Help!
