Beachbummer
- Houston TX
- SX
Is that Gaffers tape? looks like you repair will come out great.
Did someone cut that hole in with a sawz all??? Please tell me that it did not come from the factory that way....
That's the way it came.Did someone cut that hole in with a sawz all??? Please tell me that it did not come from the factory that way....
I just about spit out my bourbon when I read that.Looks more like they lost the drill bit and decided a 44 magnum was close enough.
@Drexx3 so did you do anything to fix it? any suggestions Of what might have worked for you, pictures of the solution and reported outcome?Reviving an older thread but looks like Yamaha has done nothing but continue the poor workmanship. This is from my 2020 242SE anchor locker.
I have a feeling that the location they choose to drill the hole is arbitrary and the inserts are not long enough for some of the hull locations. Or, if the come in different sizes the person on the assembly line is not paying attention to which insert they, er, insert. In the pictures below the red arrow points to the end of the insert. Notice it does not come all the way into the anchor locker.
My drain doesn’t come through the hull near this far! I’ll get a pic next time I have the cover off.Here is my fix very easy and works. 5200 around $hitty hull work and small plug bought at WalMart.
View attachment 70542 View attachment 70543 View attachment 70544 View attachment 70545
