WiskyDan
- Jackson, WI
- 242 Limited S E-Series
So, I want to update the audio on my 2015 242 Limited S and have been doing some research. I currently have the stock Polk PA4A system, six Polk DB-651 speakers, and two tweeters in the tower. I'm going to keep the PA4A system, add eight new 6.5 inch speakers, and an amp. The new speakers will replace the Polk's in the six stock positions (bow, stern, swim deck) and the two additional speakers will go in the helm area so that me and the misses can actually hear the stereo while we're underway. I'm not interested (at this point) in a sub but that could change based on feedback. I'm not looking to have the loudest boat at the sandbar - just a nice upgrade.
Speakers:
I think that I want to stick with Wet Sounds or JL but I'd like to stay around $200 per pair. I'd be open to other speaker manufacturers as well but Wet Sounds and JL appear to be at the top of the heap.
1- I've found some Wet Sounds in my price point on the Creative Audio site:
Wet Sounds XS-65i -- $149 per pair (60W RMS) discontinued but still have stock
Wet Sounds RECON6-S -- $199 per pair (60W RMS)
Are the Recon6 speakers worth the extra $50?
2- These JL's are a little over my per pair budget but would be interested in any real world comparison versus the two Wet Sounds options.
JL Audio M3-650X-S-Gw -- $229 per pair (60W RMS)
Amplifier/s
Selecting speakers seems a bit easier to me - amplifiers not so much. It appears that Wet Sounds and JL are at the top of the list but I've seen Kicker and Rockford Fosgate mentioned here as well. I don't want to spend a gazillion dollars on an amp and am hoping that I could drive all eight speakers with a 4 channel amp. The technical ohms jargon when trying to figure out if you can run two pairs of speakers on each channel is a bit confusing so how this would work with the following amps that I'm considering would be appreciated. The Polk PA4A does have an amplifier built into the system (4x 50W - 200W total) but I don't know what the RMS value is. Perhaps I could use the PA4A to drive the pair of speakers in the helm area and then buy a 6 channel amp for the other six speakers?
I've listed mostly 4 channel amps but there are some interesting 6 channel options if the PA4A can drive a pair of speakers.
Wet Sounds HTX4: Class D 600 watt 4-channel amplifier -- $649
JL Audio M400/4: 4 Ch. Class D Full-Range Marine Amplifier 400 W -- $519
JL Audio MX500/4 500 watt 4 channel Marine/Power Sports grade amplifier -- $389 (not sure about these small form factor amps - I've read that they can get pretty hot)
Maybe just get an 8 channel amp?
Kicker KXMA8008 KXMA800.8 8X100-Watt Eight-Channel Full-Range Class D Amplifier -- $764
JL Audio M800/8v2: 8 Ch. Class D Full-Range Marine Amplifier 800 W -- $849
I'm open to all ideas and manufacturers at this point and was using Creative Audio's website since it is pretty easy to navigate.
Thanks for any input.
Speakers:
Wet Sounds Black cone w/ Silver Grill High Power 6.5" speakers
6.5 inch Coaxial Speaker (pair) The XS-65i is a 6.5 inch component style coaxial. Silver Grille. Rubber Spider & Surround. Nylas frame/grille (Nylon Fiber...
creativeaudio.net
Wet Sounds RECON 6-S Recon Series 6.5" 60-Watt RMS Coaxial Speakers With Silver XS Grille And Cone (Pair)
Wet Sounds RECON6-S XS Series Silver Cone 6.5" Coax open grille (Pair) The RECON6-S are 6.5 inch component style coaxial speakers. The RECON6-S features ...
creativeaudio.net
JL Audio M3-650X-S-Gw - M3 6.5" Marine Coaxial Speakers (pair) - Gloss White Sport Grilles
JL Audio M3-650X-S-Gw - M3 6.5" Marine Coaxial Speakers (pair) - Gloss White Sport Grilles 6.5-inch coaxial system with 0.75-inch (19 mm) marine silk dome t...
creativeaudio.net
Amplifier/s
HTX4: Class D 600 watt 4-channel amplifier Wet Sounds™ Hydro-Tech™ X (HTX) Series Amplifier. Wet Sounds represents the ultimate in High Performance Marine A...
creativeaudio.net
JL Audio M400/4: 4 Ch. Class D Full-Range Marine Amplifier 400 W4-Channel Class D Marine Full-Range Amplifier, 100 W x 4 @ 2 Ω / 75 W x 4 @ 4 Ω - 14.4VThis t...
creativeaudio.net
JL Audio MX500/4 500 watt 4 channel amplifier Features: Differential-balanced inputs with Input Range switches 12 dB/oct. High-Pass or Low-Pass filters, var...
creativeaudio.net
KXMA800.8 Amplifier The KXM 800-watt eight-channel amplifier is one of the most flexible marine power plants available today. Using powerful Class D tech...
creativeaudio.net
JL Audio M800/8v2: 8 Ch. Class D Full-Range Marine Amplifier 800 W8-Channel Class D Marine Full-Range Amplifier, 100 W x 8 @ 2 Ω / 75 W x 8 @ 4 Ω - 14.4VThis...
creativeaudio.net
