pagekl
- Hanahan, SC
- Limited S
barely hand tight.. just enough to compress the seal..
Well there goes my plan, I thought that all of the units that cracked or warped had the bolt shear off. I guess the good news is that if I do have a failure it won't be catastrophic and I can keep a close eye on it maybe make it through the summer then replace the coolers in the off season. Thanks for the input.
@zelone , I don't think anyone with a 2010 240 series boat is out of the build range. There is a clear difference in the oil cooler covers/faces of the 2010 1.8 l engines. The newer coolers have an arrow cast/embossed in them that points to the side of the third bolt down. Additionally the third bolt down has a different head than the other bolts. I will try and find the thread with pics of this or will take pics of my new oil coolers for you to compare with yours but not until after work today.
Nothing scientific here but the only change I made after I got the boat was to use full synthetic oil whereas the original owner usd standard yamalube. When my coolers were replaced the dealer used yamalube and I have stayed with it since. Did the synthetic oil contribute to my Problem? Don't know for sure but I think so and recommend that if you have older coolers stick with non synthetic oil. My engines are at 330 hours now without any issues since the oil coolers were replaced.[/QUOTE
Yeah, my starboard side cooler bolt broke either my second or third year with the boat. If you didn't purchase the YES, you were out of luck like me.
#Yamaha I know you fixed this in later years but perhaps you could issue something along the lines of a #TSB to your dealers?
@davel501, what issues with the warping towers? This is the first I'm hearing of this. What year boats and has anyone else had an issue with this?
