yeah, I got some pics. My boat is actually at my dealers now for 10 hour service along with some things that were not right. I should be getting it back any day so if there's something else you'd like to see just ask..
Sidescan work well with that transducer placement?Here is my Garmin 93sv and transducer placement.
I’m getting my 10hr service also. View attachment 175419View attachment 175420View attachment 175419
Did you try the boat before the cobra steering? Does it make a big difference?yeah, I got some pics. My boat is actually at my dealers now for 10 hour service along with some things that were not right. I should be getting it back any day so if there's something else you'd like to see just ask..
Yes it works greatSidescan work well with that transducer placement?
@jjwelly thank you so much for the pictures. I have a few questions about your setup as i have bought the force recently (think that will make three of us!) and plan on installling it myself:yeah, I got some pics. My boat is actually at my dealers now for 10 hour service along with some things that were not right. I should be getting it back any day so if there's something else you'd like to see just ask..
No I didn't try the boat without it nor did I want to..Did you try the boat before the cobra steering? Does it make a big difference?
I used the MKA 42 mount. I do have the Yamaha cover, and I did initially make sure that my mount and location would work with the factory cover. However the force is a beast, and I don't want to remove the TM to use the cover, so I'm having my dealer modify the cover to fit with the TM installed. I made my mount myself. Ordered raw aluminum, routed edges and drilled holes myself, then had it powdercoated white. I didn't want to test the factory mount. I got the boat in November and had all winter to do these projects, so I had time on my side. I am starting with 24v lithiums, but I'm setup for adding another 12v to make it 36v, and know I'd never want to test the factory mount with that. After running it with 24v though, I doubt I'll ever go to 36v. I did alot of templating the boat/mount/quick detach/motor to make sure it fit exactly as I wanted...@jjwelly thank you so much for the pictures. I have a few questions about your setup as i have bought the force recently (think that will make three of us!) and plan on installling it myself:
1) appears you have a quick release? Did you buy the MKA 52/62 or something else?
2) Do you have the Yamaha mooring cover? If so, does it fit with your Force off?
3) appears you chose not to use the OEM mount? Did you buy something else or was that custom made for you? do you think the aluminum mount itself would be sturdy enough for the Force? I know the Force is a beast so was debating reinforcing it beyond the quick release.
Thanks again
I did find a pic of my transducer mount...Any pics of your force trolling motors mounted? How about transducer placement? My 2022 210 fsh is it the dealer now, just awaiting prep. Thanks
Sorry if you’ve already answered this somewhere, but where did you mount your batteries? I was wondering if there’d be room behind the tackle box compartment port side.Yeah 57” is enough for the 210 on fresh water. I’ve been on some real big lakes with it and only occasionally is there enough chop to break the surface. Any more and I wouldn’t be trying to troll in it I think. The install isn’t that hard at all imo, but I’m more handy than your average millennial. Haha
I paid to get mine done, thanks to the wife not wanting me to 'mess up our new boat' and to make a long story short, the dealer who did the work screwed basically everything up, so I ended up redoing it all myself anyway. She learned her lesson and now it all works perfectly.I wish I did mine myself.
+1 I am about to order the Force also. I could use some help figuring out a parts shopping list. It would be very appreciated.If you have questions about all the parts and pieces you’ll want/need I can help you piece that all together also.
These are things i purchased when installing the 57" Force on my 210:+1 I am about to order the Force also. I could use some help figuring out a parts shopping list. It would be very appreciated.
