swatski
- North Caldwell, NJ
In parts fiches theycall those "gunwales" I think, there is a rubber/plastic rail and an inner strip that goes inside.OH shit im a fucking idiot. Should I seal all those screws?
To seal that you would really need to seal the gap between the hull cap (top of the hull part, white) and the lower part of the hull. That is not an easy task. sealing the screws will not help much and you will ruin the boat's appearance by having sealant/silicone showing all over the rub rail. Which is not good if you want to sell you boat down the road.
