itsdgm
- Rancho Santa Margarita, California
Here's a few things you could try...
1. Try removing the lanyard and pull the plunger in and out several times. Then reinsert the lanyard and attempt to start.
2. Get under the dash and unplug each ignition switch. Reconnect each switch to opposite wiring harness. Re attempt starting engines to see if issue swaps to other engine.
3. Get into the cleanout access port. Open up access cover to area under swim platform. Unplug wiring harnesses to cleanout switches and reconnect to opposite switch.
4. Finally. Try to gain access to the lanyard switch harness. It's under the throttle controls. It is actually one plunger with two switches. One for each engine. You can try unplugging both plugs and again swapping it to the other circuit on the switch.
These measures should help to eliminate a defective switch by isolating it with a known working one. Hope it helps you out.
