Well then, just try the shallow water challenge. Step 1, know the shallows. Water depth, bottom condition, logs etc. Step 2, get on plane and run thru 12" of water while the big mouth has to raise his OB or lower unit and walk it thru the shallows. Step 3, you arrive at the same marina as the big mouth 15 minutes before him, he docks and comes over to you and asks, "how did you do that"? My reply was, as I chuckled "It's a jetboat". His last comment "Wow, I did not know you could do that.
That is how it went leaving the Sandbar State Park in 2018. We went under the bridge in no wake speed, but while I was still in the channel, I "hit it" and got up on plane before I got to the 12" deep water, I know this area and had just come thru the other way a couple of hours before. I skipped across the shallows at speed while he had to raise his lower unit and walk thru below knee deep water. I had the boat all put away and covered by the time he got back to the marina with his rooster tail between his legs.
This picture was taken in 2016 when it dried up. Two Pro Bass boats with big OB's, in a tournament, were pulled off this sandbar this past Saturday in 6" of water. You can give them all a black eye, just know what you are getting into and what your boat can do.
This is a bit too shallow to try, lol, I paddle boarded under the bridge with the Yamaha on the other side.
