UnorthodoxCreations
- Hanover, PA
I've got my 2005 AR230HO at the beach with me on vacation and of course on day 3 of 10 I'm having engine problems. I was noticing smoke out of the starboard engine that I never saw before as well as the RPMs being down on that engine compared to the other engine when in the past they sync pretty closely when throttles are in the same position. Oil level also seemed to be rising on that engine. Used YDS software to test injectors and #2 clicks once and I assume stays open versus clicking constantly like the others. I ohm tested injector 1 and 2 and they are identical 13 on my tester(manual calls for 11.5-12.5). I swapped those injectors and #2 is still the problem. I'm assuming the ECU is the problem. Is there anything else I should test before I remove the ECU and send it off for repairs? I don't expect to get the boat running while were on vacation but I'd like to get moving on repairs so I at least have a chance of getting back on the water before fall comes.
