Blower use
How do you use the blower?
  • At first startup
    Votes: 12 18.5%
  • Before every Starup
    Votes: 36 55.4%
  • Never
    Votes: 10 15.4%
  • All the time
    Votes: 7 10.8%
  • Total voters
    65
  • Poll closed .
I asked someone this the other day, too. My I/O actually had air intakes up under the windshield. So, we only ran the blower prior to each start. Once up to speed, air would flow in around the engine and out the output vents at the rear. Do the Yamaha boats do this as well?
Or, should the blower be run all the time? (Sounds like lots of answers to this question. )
I run the blowers before startup and any time it is running. My kids always help in this regard and even fight for the opportunity to be at the controls.
This allows me to have them turn it on before even taking the ropes off or straps etc.
Yamaha boats get the air intake from behind the seats on swim deck. The blowers also get air from there.
I personally would like more of a ram air setup most i/o boats have so i know air is circulating while driving.
Air goes in via the air filter of the boat. Air is for sure circulating while the boat runs. A Lot of Air. 7000-10000rpms x volume of engine.... That's a lot of air.
Unless your intakes are blocked, your blowers in Yamaha will circulate something in the order of 1/100-1/1000 of the air that the engine pumps through at cruising speeds. So, not need to run the blower at speed.
It helps to run the blower when you stop, with hot engine. Also idle a bit, if at all possible, after hard runs to cool the engines before turning them off.
Noise and line noise in the stereo would be the downsides. Not big ones in light of the risk of blowing up, but there you are.
Funny you would say that! I have come close to ripping my blowers off of the boat, had so much static and speaker noise, it was becoming unbearable. Turned out to be fixable, with @Mainah and @adrianp89 and others help.
I'm keeping my blowers! lol
https://jetboaters.net/threads/humming-noise-after-amplifier-install.18026/page-2#post-328974
