haknslash
- Lake Martin, AL
- Moomba
- Other
So you lift yours off the metal tab each time you launch? Is that so they will spin if the boat rub rail hits them? I like the idea of adding a pin or screw to secure them as I didn't plan on having to lift them up off the tab every time I launch.No issues with them moving around while driving. On mine the little "non-rotate" tab kind of secures them down. They are surprisingly secure. I was thinking about drilling a hole to put a pin in to keep them up high enough to clear the rub rail, but as long as I remember to pull up on them a little before backing in, they float high enough.
I looked on the site you linked for the covers but I don't see any for the 60" guides. Maybe they are sold out or something?
