Boat trailer guide on posts for 190
haknslash
Lake Martin, AL
Moomba
No issues with them moving around while driving. On mine the little "non-rotate" tab kind of secures them down. They are surprisingly secure. I was thinking about drilling a hole to put a pin in to keep them up high enough to clear the rub rail, but as long as I remember to pull up on them a little before backing in, they float high enough.
So you lift yours off the metal tab each time you launch? Is that so they will spin if the boat rub rail hits them? I like the idea of adding a pin or screw to secure them as I didn't plan on having to lift them up off the tab every time I launch.
I looked on the site you linked for the covers but I don't see any for the 60" guides. Maybe they are sold out or something?
Bill D
Prairieville, LA
No, I often forget to lift them, which is how I know they leave a nasty scar on the hull. :banghead: Lol.
The 60" poles may be long enough for it to be a non-issue.
haknslash
Lake Martin, AL
Moomba
Yea I don't think I'll need to lift them because the top is so far above my hull.
haknslash
Lake Martin, AL
Moomba
Washed the boat today and figured I'd take some better pics of the new guides outside so you can see how 60" looks on the 19' boat. Even though they say in the instructions to run the wire opposite side of the slide, if you're careful you can run it on the inside giving it a better look and keeping the wires safe from getting snagged on something outside he trailer.
kindtampa
Tampa, FL
How does the wiring connect to the 4 pin?
Bill D
Prairieville, LA
You splice it in to the lighting for the tail lights.
haknslash
Lake Martin, AL
Moomba
Tap into the brown wire near the tail lights on each side. Then you make a ground on the trailer for each LED.
REM835
Lebanon, OH
SX192
@haknslash I am going to try to get around to installing my set of this week. Did you end up drilling a screw or pin into the guide to the frame or just leave it for the metal tab to secure the post?
haknslash
Lake Martin, AL
Moomba
@REM835 i just left the tab and didn't add any screws. It holds it fine.
njmr2fan
Augusta GA
I added a screw to each side. After I watched my PVC pipe slowly float up the rod at highway speed. Only happened 1 time, but it always had me on edge that it would happen again when I least expected it and wasn't watching.
markp
48044 Macaomb Michigan Lake St Clair
i have sx 195 bought the 40's learned a painful lesson. 1st day out , getting boat out of the water the 40s were below the boat bumper line when trailor was in the water and the PVC tube caps tore up my side decal graphic stickers.
Went to home depot bought 60 in PVC so they always above boat bumper line. Not had an issue since. But brand now boat day 1 not a fun lesson.
DavisAR195
Happy Valley, Or
MasterCraft
I went with the 60 as well and added pads, I hope it didn't scratch it up to bad.
