YamPat
- Quebec, Canada
- 252SE
Because i will always Ask myself "what's next"
what is your dealer telling you?Because i will always Ask myself "what's next"
Might make sense if they were manf. on certain days for boats destined to Canada. No idea if they would manage their queue to destination.It is Just bizarre that nobody in the USA seems to have this issue....
can it be Just a bad batch send to Canada... that's seems odd to me when the US ?? have more than 10 Times our market
I have the same issue with the bubbles on the white part of my FSH.... It's currently been in the shop 2 weeks to repair that, a warped helm door, not tracking straight (pulls left) with more than 50% power, and port engine not turning off. That's in addition to the already replaced clean out hatch door and some exhaust hoses that either fell off or weren't ever connected.Update ????? some bubbles on the white part close to the tower
i am getting more worried...
Yeah I'm hoping it's one of those get all the gremlins out now and won't have a problem again. I have had this thing in the shop more in the 6 months I owned it than the 5 years I owned my 2007 SeaDoo.man your not Lucky ...
Are you from Canada ?? ?I have the same issue with the bubbles on the white part of my FSH.... It's currently been in the shop 2 weeks to repair that, a warped helm door, not tracking straight (pulls left) with more than 50% power, and port engine not turning off. That's in addition to the already replaced clean out hatch door and some exhaust hoses that either fell off or weren't ever connected.
Nope... FloridaAre you from Canada ?? ?
I just dropped mine at the dealer today (Ontario Canada)…bubbles, but only on the starboard side chines. My boat is a 2022 FSH 210 - I picked it up in February. Dealer wanted to push off till spring, I wanted submitted immediately since it’s within the first year. It was wet slipped. Pulled it out about every 6 to 8 weeks when we went on vacation or away. Only in Lake Huron - fresh water.
Dealer is getting info to send to Yamaha. I’ll fill the group in on what they say.
the entire hull will need to be re done or else it will just keep happeningI'm having the same issue on my 255XE. I pointed it out to the dealer in August while it was there getting some warranty work just to have it documented. It was only a small spot about 4" long with 5 - 6 bubbles. Now the issue is on two chines, both sides of the boat and runs about 10 - 12' long. I just found it all yesterday doing my end of year cleaning and have snapped pics and reached out to my dealer. Can't wait to have that conversation later today...
Where are you from ?I'm having the same issue on my 255XE. I pointed it out to the dealer in August while it was there getting some warranty work just to have it documented. It was only a small spot about 4" long with 5 - 6 bubbles. Now the issue is on two chines, both sides of the boat and runs about 10 - 12' long. I just found it all yesterday doing my end of year cleaning and have snapped pics and reached out to my dealer. Can't wait to have that conversation later today...
I'm in Massachusetts. Boat purchased from Irwin Marine in Laconia, NH.Where are you from ?
Well, just heard back from the dealer:
I brought your boat in this morning and my body technician looked at the hull to make a repair estimate.
He says that what you are seeing are not bubbles in the gelcoat and they are not air voids in the fiberglass.
What we are seeing are very small defects in the mold that were not sanded out before the gelcoat was applied.
After they applied the gelcoat and when the boat was new you wouldn’t have seen that on the surface but after the boat goes into the water and stays in the water for a while and the fiberglass shrinks from the cold water then expands again when it gets hot these little defects come up.
There is no danger of bubbles popping or water getting under the gelcoat from this.
The gelcoat is hard all along these areas, it is not soft. He showed me in a couple of spots where he pushed in with a key and the surface did not deform or push in.
In his words “the surface is not perfect but none of the boats out there are perfect. Even the really expensive boats, if you look hard enough you can find defects.”
In conclusion it is not worth it to try to repair all of this for two reasons; 1 you will not gain anything with regards to the strength or quality of the boat. 2 it will be impossible to match gelcoat so you will always be able to see the repaired spots
