broken trailer part
rsg1963
Dublin, Ca.
Matt Phillips
Lake Tahoe
Does that Fulton bolt into the existing Shorelandr pattern on the trailer?
mraz72
Rochester, NY
can we see a pic of the install?
mraz72
Rochester, NY
Here is what I think might be a solution
Take a look at the pic below, that is the stock position of the winch, if I move the winch back (towards the boat) a few inches, like they are talking about in another thread, I can then mount ANY jack that fits a 2 x 4 frame right in front of that. I am thinking about this one
https://www.etrailer.com/Trailer-Jack/MaxxTow/MT70149.html
I also ordered this from ebay, this way the wheel doesn't sink into dirt.
http://www.ebay.com/itm/Powerbuilt-Trailer-Tongue-Jack-Base-Prevents-Sinking-640784-/281241124843?hash=item417b46ffeb:g:2uUAAOSwT5tWGRGw
tdonoughue
The Woodlands, TX 77381
I have a Trailer Valet. No issues with it breaking or anything and it seems to be beefy enough to handle my 24 foot boat.
However.
The thing is not perfect by a long shot. I never move my boat in 'high gear'--only in 'low gear'. That means I crank and crank and crank and crank and the boat has moved 6 inches. It gets it where it needs to go and I use it whenever I am putting my boat away myself. But I cannot see moving it on any slope that you could see. And sometimes I need to move the boat half way in, take a break, and then do the other half of the way. So if you are not in a hurry, it is fine. But be aware of the limitations before you drop the $$$ on it.
However.
Interesting. The pre-2015 240 trailers are similar, but not the same; what I have seen in those older ones (mostly in pictures) is: 1. the bow stop sits few inches further back on the front beam (about in the middle, it seems) and 2. the transom hangs over the bunks by few inches, not recessed like mine was.
If that is the case, my theory here maybe correct and spot on.
Do they still offer two versions of the trailer valet or did version 2 replace version 1.
mraz72
Rochester, NY
Trailer jack update.
From what I can tell there isn't a bolt on after market jack that replaced the OEM tongue jack, of course you can always replace the OEM jack. The frame on my trailer is 3 x 5 so that limits the number of options.
I am going to try the Fulton xlt, it fits 3 x 5 frames and is rated up to 1500 lbs. The OEM jack was only rated to 1000lbs. I also moved the bow stop back a few inches to see if that helps. Really the entire project is pretty easy.
spwns105
Sorry to bring up an old thread. I'm having the same issues with my jack that you were having. I have a 2016 trailer. Just wondering what jack you went with, and if you moved your bow stop back any? Back, as in, towards the boat?
Thanks in advance.
Gym
Falmouth, MA (Cape Cod)
Thanks in advance.
I replaced mine with one from Harbor Freight Tools for $29. It's rated for 1500 lbs and has worked just fine for over 4 seasons now
dietz
Also blows my mind such a cheap tube/wheel is an industry standard. Can't beat the proof it worked good enough over the years, but I would pay more for a quality device, or maybe mount 2 as a backup - one wheel , 1 additional fixed for storage? Anyone mount a second on the other side?
fy- Fulton offers an adapter plate that is supposed to be welded to the trailer in case users don’t want to go the U-bolt route.
Also i keep the cheap harbor freight jack around as a spare and have used it several times. When I thought I was going to use the trailer valet my plan was to also have the cheap jack or a Fulton on the other side.
mraz72
Rochester, NY
Thanks in advance.
I went with one of the fulton jacks from West Marine, I think it is rated at 1500lbs. It was a simple bolt on and it's been great, much better than the stock jack.
I'll see if I can grab a pic next time I'm next to my trailer.
I did not move my bow stop.
