Lunarvrx
- Chaparral
- VRX
The process for drown mode is used on the PWC's by holding the throttle at WOT, this will prevent the firing, but will allow it to crank. Since the boat will not even crank unless it's in the neutral position, just pull all the plugs off of the COP's and it will dry crank.
I did it this way. Although it will not fire in dry crank, I expect fuel will still be injected. This will tend to defeat the purpose of lubricating the cylinders & rings.
