- Florida
- Other
- Other
COBRA JET STEERING LLC is offering special end of year sale pricing for select steering systems for the Yamaha jet boat lineup.
This special pricing is for www.jetboaters.net MEMBERS ONLY !
You can email me directly jeff@cobrajetsteering.com or P. M. me here.
I will need the state you are shipping the parts to, the year and model of your boat and what parts you wish to order also any questions you may have Such as are they upgradeable to accept the mega fangs or can they work together with the lateral thrusters etc.
All systems come with my 30 day satisfaction guarantee and my repair or replace warranty , both can be viewed on my web page www.cobrajetsteering.com .
For those of you that are not familiar with my steering systems.
Most parts are made of 3/16 tempered aircraft aluminum for strength, durability and effectiveness without excessiveness!
Other parts are stainless steel such as tie rods , fasteners & standoffs.
The first of the COBRA STEERING systems offered will be the latest model for the 2019 twin engine jet boats with the articulating keel.
This system is only compatible with the 2019 model twin engine boats.
The Magnum A K - 19 system. The m s r p for this system is $ 399.95 my buy direct discount price is $359
All domestic shipping on all steering orders will be via U S PRIORITY MAIL, I will also be happy to obtain a quote on any shipping costs for non domestic orders.
This system also includes the second tie rod to balance out your original steering system.
It has adjustable fins mounted on the outside of each nozzle forming a V configuration with the original rudder.
This system supplies excellent and predictable steering response at the dock , in no wake areas, in heavy traffic areas, in rough conditions as well as water sport mode or at high speed.
You will experience fast predictable steering response and improved straight tracking at all speeds.
You may choose to reduce the amount of high speed effect if that suits your personal driving preferences , plus change the setting if your needs change.
From SLOW speed to W. O. T. this system delivers .
Next is the MAGNUM A K system for 2015 to 2018 twin engine articulating keel boats.
This system also adds the second tie rod and performs the same as the A K 19 model previously mentioned.
Since this system uses the previous style nozzles it is compatible with the A K fangs & Mega Fang Plus system .
The M S R P for this system is $400 our buy direct discount price is $324.99
See Picture below.
Now we are also offering the new ULTIMATE A. K. SYSTEM. This system fits twin engine models from 2015 to 2018 It also provides a second tie rod as the two systems above.
This system uses larger fins than the previous systems and it uses spring loaded fins , these fins can be set to lift up at speed or remain down all the time for unbelievable steering control at all speeds plus the full time effect can be adjusted to several levels to meet your personal boating needs.
Not just for slow speed handling but all boating conditions like wind, waves ,boat traffic , water sports, guest operators.
This set offers the most influence and the most variations making it the ULTIMATE system.
This system is also compatible with the Mega Fang Plus upgrade .
The M S R P for this system is $500, our buy direct discounted price is $424.99
Next is the Ultimate system, including both single engine and twin engine setups.
The ULTIMATE system is compatible with most Yamaha jet boat models EXCLUDING the articulating keel twin engine boats.
It is also compatible with the single engine boats with the articulating keel up to 2018 models.
This is a spring loaded, adjustable , variable effect ,steering system.
This system allows you to choose all time steering assist or choose to have the fins rise up at planning speeds.
The special actuator holds the fins down at speed when in full time mode, or the actuator lifts the fins up removing the majority of the fin surface from contact with the water at planning speeds when choosing that setting.
Also in the full time mode the fins can be set at a variety of levels and on twin engine boats the outside fins can be independently adjusted to stagger the fins.
This allows you to fine tune the effect at planning speeds by setting the inside fins all the way down while setting the outer fins at any level you choose as those fins are the ones that provide the most effect at speed as they make the most contact with the water when on plane.
The ultimate system will provide you with the steering enhancement's you choose for the area and conditions you boat in.
The Ultimate system is compatible with the Mega Fang Plus with the exception of the single engine keel 19 foot boats.
The M S R P for this system is $230 for single or $415 for twin engine, direct discount price is $184.99 single and $369.99 twin engine set.
Next is the Cobra Venom 16x system.
This system is compatible with Yamaha single and twin engine boats up to 2018 excluding the twin engine articulating keel jet boats.
The system consists of two adjustable tempered aluminum fins per nozzle .
Each fin has several adjustment settings including the ability to stagger the outer fins when used on twin engine boats obtaining the same variable steering influence as previously discussed .
This system can provide steering assistance at all speeds from idle to wide open throttle.
It is our economy set providing several important features at a lower price than the Ultimate system.
Our M S R P on this system is $205 single and $365 twin system, our buy direct price is $164.99 single and $324 twin set,
This system is compatible with the mega fang plus or the A K fang set upgrade also.
View picture below.
If there are any compatibility questions regarding mixing and matching of my parts with other parts from other manufacturers or any other questions pertaining to these systems please feel free to email me directly. I will be happy to answer them.
Or just use the search feature on this web site for information on the systems and their compatibility with other systems etc.
Sale begins now and will run to the last day of the year or with a 24 hour notice if that becomes necessary.
These sale prices can not be combined with other discounts or offers.
See Picture below.
View picture below.
