- Florida
- Other
- Other
COBRA JET STEERING LLC
MID SUMMER SPECIAL
For a limited time we are making a special offer to those of you who purchased a Yamaha twin engine articulating keel 21 or 24 foot jet boat.
Find out just how nimble your boat can be and how easy it can be to turn at speed or when docking in tight places.
Cobra Jet Steering llc designed a special steering system to be added to the original articulating keel twin engine21 and 24 foot jet boats.
Our MAGNUM A K model specific steering system addresses several areas of your original steering.
First we balance the work load on your steering helm and cables by adding a second tie rod between the rudder and the left side nozzle so that when turning the rudder the work is divided evenly to both sides, this also provides an even push / pull effect on the cables and helm when making high speed turns in either direction .
Having two tie rods also adds redundancy to the system.
Our second tie rod is just the beginning, we then add steering fins to the outside of each nozzle placing those fins above the rudder and out to the side of each nozzle to form a V configuration to provide added influence and better response from idle speed to top speed.
Having a huge keel down the center of your hull makes the boat want to resist turning at speed, the extra fins assist you in making faster and sharper turns at all speeds, NOT JUST SLOW SPEED !
We also added our new A K FANG design for a reduction in steering resistance in the nozzles the helm and on the cables by having the fangs go forward of the pivot point of the nozzles.
This positioning also assists in adding even more reverse control during docking as the fangs help direct the water as it exits the reverse portion of the steering nozzle.
Our Magnum A K system fins are tempered 6061-t6 aluminum for strength and reduced profile.
Our second tie rod is heavy duty stainless steel with adjustment capability similar to the original tie rod however our tie rod ends are also built from stainless steel for greater strength and durability, unlike the original aluminum ends.
For a limited time we will be offering you a special incentive on this system.
We chose this time of the season as we felt you hopefully had ample time to use your new boat and learn that it may not handle quite as well as you expected when you purchased it. If so you may wish to make the boat more user friendly so others will feel comfortable operating it while you enjoy some water sports or just relaxing.
So if you feel that you would really enjoy the boat better if it had more precise and responsive handling at all speeds and in reverse. Send me an e mail today to take advantage of this special offer!
IF YOU ORDER THE MAGNUM A. K. STEERING SYSTEM Via a P M or email directly to me jeff@cobrajetsteering.com , we will provide you with a set of " A K Fangs" for your system at no additional charge.
And"Free priority shipping" in the U S A.
This is a limited time offer that is not valid with other offers or promotions. This system comes with a 30 day money back satisfaction guarantee as always.
15 years experience , three U S patents with a forth pending , steering is what we do.
MID SUMMER SPECIAL
