- Royal, AR
- SX
This could be helpful for those of us with multiple trailers of differing sizes.
In 2010 I bought a chrome version of this product. I chose it due to the simplicity of changing ball size and its high capacity of 10,000 pounds which matched well with the Class V receiver and 12,000 pound tow capacity. While building my home I towed up to 14,000 pounds using the 2 5/16th ball several times.
Through 2012 and 2013 it worked well switching from the 2" ball for the boat to the 2 5/16th for the equipment trailer. I typically used the butt of a pen or a key to start the removal of the pin that holds the ball in place.
Unfortunately in the spring of 2014 I found that it had succumbed to two years of salt water boating. The pin that held the 2" ball in place had corroded sufficiently that I had to use a mini sledge and a punch to drive it out. Since then I have been using a triple ball shaft that I remove from the receiver and rotate to choose a ball size.
Today I noticed that a stainless steel version of the Covert-A-Ball is available. I am adding one to my Christmas Wish List.
You can find more info at http://www.convert-a-ball.com/ballsshanks.htm
